- Apr 25, 2005
Filed under: Coupe, Budget, Sedan, Recalls, Safety, Chevrolet, GM, Pontiac
General Motors has announced that it will be recalling 778,562 compact cars after six people were killed in accidents, partially due to the airbags' failure to deploy. An issue with the ignition switch is causing the airbag issues, as well as causing the engine and other components to shut off without warning. The recall covers the 2005 to 2007 model year Chevrolet Cobalt and 2007 Pontiac G5. (Note that the Cobalt pictured above is a 2009 model.)
According to a report from Automotive News, a number of factors can cause the ignition to switch out of the run position, including weights on the key ring, rough or bumpy roads or other "jarring" events. Any of these situations could lead to some vehicle components not functioning properly.
There have been five fatal front-impact crashes that took the lives of six people, although as a GM spokesman noted, all five of the crashes happened off road and at high speed. In each of these cases, though, the lack of airbags wasn't the only lethal factor - alcohol and failure to wear a seat belt also played a role. Outside of the fatal accidents, there have been 17 other crashes where airbags didn't deploy. It's unclear if any of these crashes were caused by the engine shutting off.
According to AN, GM is contacting dealers to report to their local dealership for a new ignition switch. Naturally, all work will be done free of charge (presumably, Pontiac owners will need to report to Chevy dealers). Customers that haven't or aren't able to report for service, meanwhile, are being asked to remove "non-essential items" from their key rings. 619,122 of the affected cars are registered in the US, while 153,310 are up north, in Canada. South of the border, 6,130 cars are affected.
Once the National Highway Traffic Safety Administration has posted its recall bulletin, we'll be sure to update this post.GM recalling 778,000 Cobalts and G5s, six deaths reported originally appeared on Autoblog on Thu, 13 Feb 2014 10:15:00 EST. Please see our terms for use of feeds.
More...
More...
