Got a1995 firebird 4.3L. ?
  • Thread starter Thread starter Walt B
W
Walt B
My 1995 bird is linking walter were the motor and trans bolts together..Never seen this before please help.
only thing there is engine freeze plug...tranny or engine mys come out to repair...next time check your anti freeze... tester cost 5 dollars......freeze plug????
right - two freeze plugs in back of block go into water jacket. Pull off the dust shield and look up behind the flywheel and you should be able to see the water coming out. Assuming you meant water and not really walter Walter.
