beertracker
- Nov 30, 2016
Ignore my post. My mistake this won't work since the engine is internally balanced and the harmonic balancer is externally balanced. bt
I am building a mild Pontiac 455 probably 400 hp and 440 lb ft of torque. It's a not a race engine. Searching for a harmonic balancer I found this one and wanted to ask if you have heard of any reliability problems with it?
bt
Pontiac V8 6.625" External 25oz. SFI Approved Harmonic Balancer Damper
Fitment: Aftermarket Modifications Needed
Brand: Speedmaster
Part Number: PCE291.1065
Part Type: Harmonic Balancers
Engine Balance: External 25oz.
Safety Rating: SFI-approved 18.1
Degree Markings: Yes
Degree Marking Range: 50 BTDC to 10 ATDC
Outside Diameter (in): 6.625 in.
Harmonic Balancer Material: Steel
Harmonic Balancer Construction: Fluid
Harmonic Balancer Finish: Black zinc chromate
Mounting Hardware Included: No
Quantity: Sold individually.
Notes: Additional timing/degree marks at 90,180 and 270 degrees.
bt
Brand: Speedmaster
