Hey!
Question if anyone can answer. I own a 1994 2.0l Sunbird and I have been trying to troubleshoot a turn signal issue.
When I turn my turn signals on, they will work for 2-3 flashes. I can hear an audible click coming from the flasher, and the lights do come light up on the exterior of the car. However, these 2-3 flashes are very weak and by the 3rd flash is hardly noticeable. This works for either the left or right turn signal with the same result. The hazard lights work just fine.
I have checked the fuses, replaced the flasher and am wondering if it may be the turn signal switch. I don't understand why it would work after leaving the car sit for awhile, then when I return it does the same as mentioned above.
Thanks!
Thanks!
