sunlady
My '94 Sunbird has been showing the following symptoms that seem to indicate an internal coolant leak. The most obvious symptom is that she tends to start very roughly when the engine is cold- choking, misfiring, and trying to stall, unless you give her plenty of gas. After a few minutes of this, the engine smooths out, and seems to be running fairly normally. This rough starting sometimes seems worse when the weather is cold or damp. Gray steam out the tailpipe has been noted, but is not always present. There are signs of water getting into the oil, although not in great quantity. The rate of coolant loss is quite slow, and the car does not tend to overheat. My question is: Am I dealing with a head gasket leak, or with a leak in the intake manifold gasket, or something else entirely? What's the best way to find out for sure?
