2004 Pontiac Montana minivan
6 cyl. 3.4L
70K miles
A week ago, we were driving the van around town for 20 minutes or so and just as we got home, the warning message came on indicating it was overheating. Shut off the ignition and the fan continued to run for a couple minutes. Popped the hood a few minutes later. No steam, no hot "smell" at all. Coolant level in overflow tank is fine, about 1/3 full. Next day, started the van up and the warning message came on saying the van was due for an oil change. Just had it changed a month ago and have only driven a few hundred miles since then. Drove it around for about 20 minutes and the temp gauge never got above halfway.
Took it to a local dealership and they said it had a blown head gasket, repair estimate $1500. The son of a buddy of my Dad is a mechanic so I had him come to my place and look at it. No signs of coolant leakage anywhere externally. Coolant level in radiator fine. Checked the oil via the dipstick and it looks normal, not cloudy or "creamed coffee" colored at all. He had a portable code scanner with him and that didn't show any errors at all.
Dealership shop says the oil via the dipstick would look fine as oil floats on top of water and the stick only reaches the top quart or so of oil. Others have told me if the head gasket is leaking internally, the oil will not look right via the dipstick.
Keeping in mind I know little to nothing about engines, is there any definitive way I can determine if the head gasket is indeed faulty or if instead it was just some sort of glitch with the sensors and the dealership is just looking to screw me? In doing some research online, the Montanas have a reputation for blowing head gaskets at 70K miles so it wouldn't surprise me if it was indeed bad. But, all indications I'm seeing tell me the head gasket is fine?
Any input would be greatly appreciated.
6 cyl. 3.4L
70K miles
