headlight motor question
mook627
ok guys um the right headlight motor goes up and down....yeah i know i look like an idiot at this point.. lol just wait um but when i goes up it just runs and runs and runs ...when it goes down it just runs and runs and runs the gears are fine but my question is... thare a way to fix this i don't know if its a relay or the .. well i call them loabs inside under that cover with the three screw.. do those need adjusting if so how can i adjust em because im a cheap sob
Yes it is the relay on the side of the motor. I had the same problem until I tools the relays out. Although until I get new ones they are stuck up. My local parts had them for like 12$ each.
thanks man i have extra relays in a box that came with the car gonna see if thare anygood or not
If its a First Gen setup (84-86) it sounds like bad limit switches. Those motors have built in switches to kill power when they reach the top/bottom. When the switches fail the motor will hit the limit and twitch constantly.
Second Gen (87-88) use a headlight control module, under the driver's side fender to control the motors.
Your limit switches inside the motor are dirty/bent, you have a lot of dirt that does not allow the worm shaft to slide properly, or your nylon gear has some teeth missing.
The center worm shaft of the motor will move slightly up or down and open a metal contact when the headlight reaches full up or full down.
To fix it you need to remove the motor and drill out the rivots. You can then use new rivots or some folks will put them together with screws and nuts.
The biggest problem is the nylon bushings that the gear runs on deteriorate and pieces get caught by the switches and cause them to not work.
You can buy a rebuild kit for these at:
http://rodneydickman.com/catalog/product_info.php?cPath=32&products_id=230
These include the new bushings and a metal gear. Also if you click on the link above there is pics of what the inside looks like and links to step by step instructions on how to open, rebuild, clean, and reassemble the motors. Rodney uses delron bushing (they don't wear away) and metal gears (no teeth crack off).
I should also note that if you want to clean and regrease the motor without buying a rebuild kit and you find some teeth missing from the gear, Just remove the gear and spin it 180* and re-install it. The motor only uses half of the gear to open and close. So if one half is stripped you can get away with using the other half.
thanks i'll try that i have a spare left motor that the packrats goto and chewed the wires it should have a good set of gears if i can swap the gears out with the right side if thare the same gears
