86305_TA
I got an 86 T/A and neither of my headlights pop up. I was thinking replace the relays and that would be fine, but I'm not sure where the relay is and even if that would fix it. I have to turn the little wheel to manually put them up, but the left one winds itself back down so I have to put a zip tie from the wheel to anything to keep the wheel from winding itself back down. When I have the zip tie holding the wheel in place and the headlight up the little motor that the wheel is attached to gets really hot. The one on the right headlight doesn't get hot, also if I leave the left one up it completley drains my battery. So I'm not positive what to replace to fix all this and I'm tired of having to get out, open the hood spend 5 minutes putting up the headligts, looking for a ziptie, and then cutting the ziptie and put the right headlight down when I get home, and for some reason now even if the headlight is down it still drains my battery. I used to be able to put the headlights down and it would be fine but tonight it started to drain the battery even if the headlights are down and the little motor stays hot. Any info would be helpful.
