Headlight replacement
  • Thread starter Thread starter skeeter395
S
skeeter395
My headlight burnt out today and I attempted to change it. I removed the obvious 3 screws on the top but the bottom was sticking. Does anyone know how I can remove this without breaking it? Thanks for any help.
doesnt it have a bulb that is removed from the rear?
Yes it does but I can't get to the back of the light assembly unless I remove the light assembly. there are three screws on the top holding the light assembly in that I can see. So is there another screw on the bottom or is it a clip or what. I can move it around not bad with the three screws out but I cant lift it up to change the bulb.
Thanks,
Scott
The headlight body has plastic latch at the back that gives you filling that it is connected to something. Do not be afraid to pull headlight out. Apply moderate force and get headlight unlatched. After that just try to move headlight and pull it out from its place.
I have changed light bulbs and it definitely works.
