zekeharn63
- Mar 9, 2013
I am currently having problems with my dash, heater, and power windows. When I start my car (this dose not happen every time I start the car) my dash, heater/AC, and power windows do not work, but my radio works and I can turn on my headlights manually. When this problem first started I was able to press up on the window switch and that would turn everything on (heater, power windows, dash lights, speedometer, gas gauge, heat gauge, auto setting for the headlights, cruse control...ext, basically everything except the radio), but now that does not work. Now I have to drive about 1 minute or 2 down the road and everything will turn on eventually and when it does turn on everything turns on at the same time, like I said though this does not happen every time I start the car, but is happening more often now. This problem probably started around christmas time, and has been on and off since then. In the spring of last year I had after market head lights and radio installed, not sure if this has anything to do with it or not. I have tested the battery got good voltage readings, and checked all the fuses and none were bad. Any input/help would be greatly appreciated.
