Hi All,
I have superduty heads on my 455 TA. When the intake manifold is fitted with the superduty gaskets the heat riser ports on the heads aren’t completely covered. It’s as if the gasket doesn’t go up and over the heat riser port but straight through the middle of the port ? I’ve seen that people opt to fill the port but is there a correct gasket I can get ? Is the 73 intake manifold the same dimensions as the 73 superduty manifold ? I’m not sure that it’s the standard, superduty or aftermarket manifold. I’ve attached a photo with the circled area.
Thanks
Thanks
