Heater blowers and more
fishonron
KS
Today both front and rear heater blowers quit working. I also noticed that the rear window wiper stopped working too (it was fine yesterday also).
I'm not sure if it's related or not but twice yesterday and once today when I turned the ignition nothing happened, turned it a couple more times and then it would start.
I've checked all of the fuses and they are good.
Any help would be appreciated.
Thanks!
what year is the vehicle?
I figured it out. There was a wire in the harness that lays over the battery and under the fuse box that was exposed out of the slit in the harness. That wire corroded through and was only connected by a few strands. luckily there was enough slack in the wire to give me just enough to solder the connection.
glad to hear you found it
