Help a NEWBIE with 97 firebird probs
Cedonulli
OK. I was a chevy/pontiac guy from 1970 to 2002 You name it I owned it cars, trucks trans ams, z-28, yadda. Got a big Ford (sorry for cussing) diesel truck in 2002 and lost touch w GM stuff,
17 year old daughter just wanted first car so I picked up a 97 firebird 3.8 liter
at an auction for $1700. Has 138K on it. Got it home and notice a noise thats coming from the back--outside it seemed to be the muffler but inside seems like where the t-tops are stored---almost like a radio left on with no station--buzzing kinda. Notice it change if you put on other electrical stuff. Could that be the fuel pump? Are those in the tank or under the back of car? Does that loud humm mean its going bad?
LEFT turn indicator wont flash. Funny thing is the front right one stays on as long as the key is on. Not flashing tho---just on but it will flash if I flip the stalk up. Looks like the turn lights are in little pods inside scoops that almost look like aftermarket driving lights. How the h do you get those open? Have a screw on each side but that looks like it just takes the pod off the bracket.
The check engine light is on but the thing that worries me most if once in a while, usually at idle or slow speed, it feels and sounds like Ive lost spark to one cyl. Rough. Then it goes away.
Edmunds said that model up to 1999 was a 5 star car EXCEPT the 1997 which had two large dollar problems. Tranny and Injection system. I looked up the original dealer who told me that no GM garage had a service record of fixing those items so Im guessing at 138K it would have gone bad if it were going to??
How hard is it to change the fuel pump? The valve covers seem to be leaking a bit and I can smell burning oil. Are those easy to do on my own?
Darn---wish I had my 69 Z back. These computerized things are past my ability/equipment.
Finally, I can change the disk brake pads on my F-350 in about 20 minutes total with my eyes closed. Are the pads easy to do on this 97 without any special tools? Any comments from any 97 3.8 owners? Thanks gang.
The fuel pump will make a humming noise. Just because it is making noise doesn't mean it's bad. The turn signal sounds like a bad bulb or ground Go to Auto Zone or other parts store and get the codes scanned and report the codes and we can give you a direction to look.
to change the front turn signal bulb you have to go down from the head light opening.Take the cover off surrounding the headlight for easier access and it should be straight down. The lights stay on when the car is on. I have a 98 3.8 with 133,000. The turn signal bulb just twists out and the housing that the bulb goes into is held in with three sheet metal nuts on plastic shafts that stick out of the housing. You don't have to remove the housing to change the bulb but my lenses were so dirty you could hardly see the light so I took them out while I had the headlight out and washed them out with detergent and water in the kitchen sink.
OK now Im worried---got codes from Autozone
Three codes and two sound nasty. P1870, P0420 and P0300
The thing does idle rough and sounds like intermittant misfire or dead plug. Other than that it had just passed our states emission test. On the road it runs well and has power. P1870 has some nasty sounding stuff about the transmission. Excessive slippage, Internal trans fault, etc. Edmunds did say that the 1997s had some major trans problems with a valve of some sort, and major problems with the injection system. I just paid $1,750 for this at an auction as I first said---the interior is like new. The paint has only tiny marks, it has expensive chrome mags, thought I got a deal but if its the worst possible thing in these three codes, I have to dump this thing fat and hope not to lose my daughters money!!! She paid for it from babysitting. She already loves the thing so Im going to feel pretty bad about buying it.
Tigard Oregon. Just a quick trip away! Thanks though. Ive discovered new problems since this post started. Jeeze---
