BlackWS6TA
- Jul 20, 2012
My 2002 TA WS6 last night started acting up while driving home. The lights on the dash just went out and so did the radio lights. The gauges still work as does the radio, I just cant see what station its on. The lights on the steering wheel work, the odometer, and trip counter all still light up. I checked all the fuses (the panel next to the driver on the side of the dash, and the 2 panels under the hood, no blown fuses). The dimmer switch still works because when I adjust it, the lights on the steering wheel adjust from dim to bright.
When the ignition is on and the lights are off, the radio lights up and works, however when I turn the parking lights to on, or to the headlights on position, the radio lights then go off. The dash lights never come on.
What gives? Help!
Dan
What gives? Help!
Dan
