callmesteveo
- May 24, 2012
I am really hoping that someone can shed some light on this ongoing issue I’ve been having with my Sunfire. It’s a 1995 2.2L with like 129,000 miles. My problem is this…I was leaving my buddies late last night and when I started my car it took a few seconds of cranking, as it sometimes does, before it finally started up. Once started I could feel it was idling kind of sluggish. When I put it in reverse and pushed on the gas the car rumbles as if it wants to die but it still moved very slowly and sluggish. Made it to the street and put it in drive and it was doing the same thing. You push on the gas and it just wasn’t driving/pulling/catching/getting then power it should (however you want to word it) but it was just sluggishly moving. Then once it had been going for a sec it would catch all the sudden and you get the pull you should be with how hard you’re hitting the gas. Then it would start rumbling again. Then whenever you slowed down or stopped it would start all over again. Made it back to my buddies house and had my friend, who is above average in car knowledge, and let him drive it. It did the same thing. I wasn’t paying that much attention but he said it wasn’t going above like 3000 RPM. We just barely had the power to make it back up his driveway. We have concluded that it’s obviously something fuel or spark related. The car runs fine other than this issue. I have had this happen a few times before last night where I would push on the gas and not get the power that I should but in the past it would happen quickly and then stop. Never to the point that I couldn’t drive anywhere. I do often have to crank it for a few seconds when starting for it to finally come on. The check engine light has been coming on for a couple of months now. I’ve noticed it comes on most usually at night or on days when it’s wet and rainy. Brought it to get the error code read and apparently my fuse that controls the car lighter is blown and that also controls the error reader. I’m assuming it’s a 02 sensor or sensor of some kind. My buddy and I just not even two weeks ago did some basic maintenance on the car. We changed the air filter, fuel filter, oil + oil filter and spark plugs + wires. The car has run fine since then up until last night. When we were changing the spark plugs there was one (the one on the far right looking at the engine) that had oil on it. We thought maybe it was just from all the grimey stuff on/around the plugs on the engine heating up and leaking in.
Well that’s about all the info I can think to give guys. As I said, we’ve concluded it’s the spark plugs or maybe the fuel pump. Or something else fuel related. Don’t believe bad 02 sensors would cause this, would it? Or maybe a bad PVC valve? Any input would be greatly appreciated. My buddy and I are going to check the spark plugs after work today and go from there. Definitely going to try and find and replace that fuse so we can see why my check engine light is coming on.
