Help Identifying Wiring Harness Wires
tashalynn
Hello,
The rabbits made a nice meal from the main wiring harness. 🫣
We are going to attempt to repair (add wire, solder and heat shrink) to save from replacing the entire harness.
The wires don't have gauge numbers and there is a hollow black tube in there (vacuum line??). They appear to all be the same size except the purple.
Can anyone help me figure out what wires I need?
Any guidance welcome!
Thank you.
The tube looks like vacuum line but it's unclear what you are asking about the wires. A wire stripper has gauge numbers on it. Use it to determine what you need size wise.
Looks like14 Guage wires, except for the purple and the black which looks like a 12 guage.. tube is vacuum for the climate control system which you could cut square and slip rubber vacuum hose over.
Doug in P.R.😎
