I have just resurected my 88 Fiero 2.5l after 6 years laid up. Amazingly everything worked. Drove round the block and handbrake dragging slightly. Service engine soon light on but no codes stored. Fixed handbrake but now an engine problem. Car starts fine and idles beautifully no miss firing whatsoever. Idle speed drops as engine warms up. However open the throttle ever so slightly and the engine cuts instantly like an electrical cut. Blipping the throttle is the only way to keep it running. However once over 3500 rpm it is possibly to hold steady rpm on the throttle. Any attempt to lower the rpm and it instantly cuts.
Standard car apart from cat removed. Just removed EGR and blanked it off. No change. Blown out fuel line and filter. No change and no crap. Not suspecting fuel pump due to the steady high revs. Possible TPS fault that does not give code? Will see if any of my mates has a digital waveform scope. Unfortunately bolt on the TPS damaged so going to need a big strip down to remove it.
Please bear in mind I am over the pond in England so nipping down the road for a spare part to try and if no luck try this is not really an option. I need to know what it is and order in from your part of the world. Reading other posts this seems to be a common problem with slight variations.
Thanking you in anticipation.
