bluesmokennoise
Member
- Aug 14, 2023
I've got a 1991 Pontiac Sunbird LE convertible (2.0L 4 cyl) of which I have done extensive restoration. I replaced the doors and installed new window motors on both sides.
(It's a 2-door). My problem is that the passenger side power window when raised all the way does not close and seal entirely with the upper rubber gasket seal. The forward portion of the window is tight with the convertible top but the further back you go there becomes a gap between the window and the seal. When raising the window it appears that both forward and rear are
extending fully. I have also investigated the convertible top and it appears to be level. I've got the motor, regulator and cam all reinstalled and since there are
24 rivets involved I would like to avoid the need to drill out all those rivets and re-install them if I can but I will.Surprisingly the installation of the motor and regulator on the driver's side went smoothly and is perfect. Can anyone offer a suggestion as to how I might be able to bring the rear portion of the passenger glass up to where it is level and seals with the forward portion?
