1st, buy a haynes repair manual. buy some tools. read the manual and go from there. all fuel injected vehicles have the fuel pump in the gas tank. so, draining the gas from the tank, removing the straps from around the tank, dropping the tank and taking out the fuel pump. you have to use a brass punch or similar tool (the manual will confirm this) because you must tap on the tab that holds the pump in the tank. brass does not spark when tapped with a hammer. good luck.
