Help!
djm123
All of the above lights are on..
Car appears to be running ok. The red light is on yet its not overheating its not the battery..
ETS? ABS? cHECK ENGINE, SERVICE ENGINE
Can anyone help?
You need to have the computer scanned for the codes for the check engine/service engine. Is the engine running and driveable, if so go to autozone. The ETS/ABS could be a bad wheel sensor which either has to be scanned or check with an ohmmeter.
