High beam indicator on with low beams
sgip2000
Hillsboro, OR
Hello everyone. I need help with a weird headlight problem on a 1999 Sunfire SE.
First off, I know my issue isn't headlight harness related as I just rebuilt that and all lights do function.
My problem is that the wiring was hacked at some point in the dash area and now the low beams and high beams seem to be reversed. The high beam indicator comes on with low beams and off with high beams.
Does anyone have a close up photo of the wiring connectors that attach to the turn signal/headlight switch?
Thanks.
have you tried finding a Hanes manual and looking at the wiring diagrams or check if autozone has them available?
Yes, I have. Thank you. The colors don't seem to match the paper diagrams. Maybe it was changed over the years?
