If that doesn't get you anywhere, on the driver's side of the steering column there is a shaft that runs from the high/low beam selector on the column down to the actual on/off switch. those switches fail often as I have replaced 4 on earlier model GM's, and knowing GM like I do, they are probably still the same design if not the same part#. they are cheap and relatively easy to replace once you get the access panels off.
