Catalina Kirill
Member
- Jul 15, 2021
Another day, Another issue.. As the title suggest, after I changed the carb gasket (because it was leaking) my stock 400 with TH400 trans and stock quadrajet idles way to high, and best of all. Won't shift any further then first.. Before i took the carb off, everything was fine. Fine idle RPM, and shifter like butter. Except it was a little shaky because of the broken gasket. Whilst in there, i changed the spark plugs. Thats it. I even left most hoses on it and just let the carb dangle of a wire mounted to the hood when changing the gasket.
I took the carb back off to check if any valves are stuck, but everything seems just fine.. What is happening here?
Greetings from the Netherlands!
