vacuum lines?
dont know a bunch about that car or engine but im sure there are a lot. and theres no reason to replace them all. a vacuum leak is usually the case for a high rpm at idle. check the idle speed control. does it sound like you have a vacuum leak? get a can of carb clean or brake clean and spray aroung seals for the manifold and all the vacuum lines, anything that has to do with vacuum. if engine sound changed or speeds up, try to narrow down what it is thats leaking. you can try cleaning the carbon and crap off the throttle plate too.
