Hissing sound from vents.
Stephen0523
Member
Hello.
I have a 1989 Pontiac Sunbird LE.
Just recently I have been hearing a hissing sound coming from my vents.
When the fan is in the off position I hear a hissing sound but when the engine revs up is hardly heard at all.
I am thinking it might be the controller but I am not sure.
Any advice would be greatly appreciated.
have you looked under the passenger side dash to see if you can locate the source of the noise, a possible broken or disconnected vacuum line?
Yes it sounds like a broken or disconnected vacuum line or one mad snake.
Hello all! It has been sometime since I got carried away with life!
My problem has been solved only because I had to replace the control unit and luckily I have a new one on hand! No hissing and everything is working great!
glad to hear you are still with us and have solved the problem
