P
Pucha
don't want to pop-up in one motion? When I turn the headlight switch on the pop-up headlamps rise slightly, hesitate a bit, partially fall down and then after a few seconds, reluctantly pop open to the full up position. I can see where the twist adjustments for each headlamp assembly are located, but don't know if I should twist knob clockwise or counter-clockwise...and don't see any reference in the original owners manual. Is this a do-it-yourself fix or more complicated?
