How can I find & print a wiring diagram for my 1984...
  • Thread starter Thread starter FIEROFREAK
F
FIEROFREAK
...pontiac fiero SE? I HAVE 2 WIRES UNDER MY DASH DISCONNECTED & CAN'T LOCATE A CONNECTING POINT. 2 SINGLE MALE PLUGS DIRECTLY BEHIND FUSEBOX. CAR TURNS OVER BUT WONT START. I'M IN THE PROCESS OF TROUBLESHOOTING & DESPARATELY NEED THIS DIAGRAM. FUEL PUMP DOES NOT ENGAGE-YES IT IS NEW. NO FUSES BLOWN. AT A LOSS.
Your best bet is to go by the Pontiac dealer and see if he has one you can copy, they usually will let you on an older vehicle.
Or the good ol' sthadby are in the back of Haynes manuals. Good wiring diagrams can also be tracked down at larger libraries.
I own and work on fieros... have you tried replacing the ECM (under your distributor cap)...this is a common failure part in Fieros The wires are there for optional equipment you probably don't have installed in your vechile. does your pump turn on for a second or two when you turn the key on?
