how can i stop my blinker on my pontiac grand am 2000 from blinking to fast. and how
  • Thread starter Thread starter quaearfat203
Q
quaearfat203
can i change the bulb? i failed inspecion testerdy because one of my blinkers was blinking to fast. how can i fix this problem.
blinkers normally blink fast when you have a bulb out somewhere else
change your broken buld and it will return to normal
+1 on a bulb out somewhere. Another possibility is that there is a problem with the combined tail/brake light bulb or socket, putting too much load on the flasher.
Another solution would be to get one of the electronic flashers that have a steady rate no matter the load. Not sure how reliable or long-lived they are, considering AutoZone sells them.
