How do I change a fuel filter on a 2002 pontiac grand am?
  • Thread starter Thread starter T-Bone
YOU NEED A SPECIAL TOOL...THIS SHOULD HELP
http://www.autozone.com/az/cds/en_us/0900823d/80/05/15/23/0900823d80051523/repairInfoPages.htm
it should be back by the rear tire on the drivers side. take a line wrench and unscrew the lines from the filter and replace the old filter with the new 1.
You may want to start it and pull the fuel pump fuse and let the car die. This will bleed off most of the fuel pressure.
