How do i check my ac motor/freon?
Luke_Warm
It's been real cold where i live recently and I've been able to get heat until now, it came back on briefly the other day and now won't work at all. Not getting an air when i put it on max.
The ventilation fan uses a resistor to control fan speed. The resistor may have burnt out or depending on what year there also might be a high speed relay . You made no mention of the year.
it's 1976 model
you should have a high speed relay along with fuses that can be checked
