how do I install a 1999 pontiac sunfire
  • Thread starter Thread starter Ugly Forever S
U
Ugly Forever S
headlight? I am under the assumption there are 2 bulbs, one is for the light thats always on when you're in drive, and the other bulb is for both low and high beams. My low beam isnt working. I have the bulb but cant figure out how to install. I'm too embarrassed to ask someone irl so I'm asking on the internet.
help! I dont want a ticket
youll see 2 plastic tabs when you pop your hood right on top of the headlight assembly. they should unscrew and you can pull the whole thing apart. The other way is a lot harder but you can change it without taking anything apart. Get under the car reach your hand into it from the back and unscrew it. That way is harder but if you have small enough hands it can be done.
