How do I remove the instrument cluster of my 1999 Pontiac Sunfire?
John Love
How do I take the dash cover off too, there is something rattling in the air vents so I need to remove and clean it
Thank you
disconnect the negative cable on battery
and then the trim under windshield at the front most of dash is clipped in work your way over from drivers side with a little gentle force it will pop up and reveal the hidden dash bolts.
remove the radio trim bezel (2 philip screws when glove box is open pop out and towards passenger side) remove the 1 dash screw between sterring column and radio
on either side of the dash (drivers side fuse panel and the passanger side trim remove the philips screws) then remove all the torx screws (i think their were 4 on the top the 1 between sterring column and radio) and 2 more hidden under the glovebox trim. simply remove the screws securing the glovebox trim and then remove the 2 hidden dash bolts.
On the top above the airbag door are 2 gold 7mm screws remove these as well. then remove the entire dash by sliding toward and out passanger side door is easiest.
remove the 2 torx screws holding the cluster in place disconnect the 2 electrical clips
reinstall in reverse order :)
