How do I replace air temp "motor" in a 99 Montana
bighank
Have a defective air temp blend "motor" in a 99 Montana. See in the factory manual its 2 screws and an electrical connector on the left side of the HVAC housing. Has anyone done this. Looks like you have to be Houdini to get in there. After removing trim panel on the drivers side what do you have to do to get the motor off and on again. Mine sticks in full hot or cold. Almost froze this winter till it moved back to hot. Need to go junkyarding and get another one. What is the easiest way to get to this without pulling apart half of the car?
BIGHANK:confused:
