How do I replace the high pressure line on the pwr steering pump on my Pontiac...
  • Thread starter Thread starter The Coach
T
The Coach
...Montana sv6? The hose leaks all the fluid out. Where is this located?
well if you know its a hose leaking then you should know where the hose is sorry lay down on ground slide under look up have a flash light shine on hoses that have oil on them they wil lbe the smallest hoses under car one wil be bad coudl have someone turn the wheel while motor is running and it will spray it out then you see which one it is then with a wrench you remove that hose take it to any parts store with you and put on the new one fill again and work wheel back and forth a few times to get air out of system... can be done at home might be easier to have someone do it sometimes they are a pain to get to
