not to hard you will need some spring compressors, or you wont be abel to do it. just take all the bolts off to the strut, use 1 or 2 spring compressors for each side and compress the spring.
should be simple just be carful they can be dangerous and deadly if the compressor slips off.
Changing the struts is not bad but you must have the car aligned afterward or the tires will wear quickly .. whan struts are changed the settings change due to the positioning of the strut in relation to the lower control arm and tie rod ends , this must be realigned to proper spec on an alignment rack..
not something you can do your self ...
