if you can change a flat tire you can do brakes about 25 bucks if you dont need to have rotors turn or replace pads are easy this site will tell you and there is a video if you look same place or youtube.. just type in how to replace brake pads once you do one you can do them all pretty much all the same in how they work bolts and pins and shapes of change but how they work are same on every car.. call autozone for price of pads call a few shops and get a price to do it all .. if you have been grinding then you need to have rotors turn down smooth again not much harder but more work which you also can do at home also can find how to do it same sight along with other ways by typing in how to replace and name of parts
Maybe $30/set. Simple to replace, but remember L R sides are mirror images of one another. Don't overlook proper system bleeding procedures and always road test for safety.
Good Luck!
front brake pads will run about $40 rear brake shoes will cost about $20 and it is realtively easy to install pads, if you know how. The shoes are more difficult to install and should probably be left to a mechanic.
