F
Fatdude427
...Firebird? The original engine is fuel injected, of course. It is the 3.8L V6.
How much would it cost just to rebuild the 3.8 motor to stock specs?
How much would it cost instead to replace the V6 with a mild 350 Chevy engine with, say, 300HP?
Would I need to remove the gas tank to remove the fuel pump?
Would I need to use a different radiator shroud?
Would I be able to just bolt on the 350 engine to the stock auto transmission (I believe it is a 4l60E transmission)?
Would I need to change flexplates?
Would I be able to bolt on any of the accessories from the V6 to the 350, or would I need to purchase all new accessories? By accessories, I mean the PSP, the Alternator, the starter, etc. I know that I would need a new intake, a carb, etc.
What about the motor mounts? Would I require new ones?
How much would the entire job cost to install the 350 Chevy motor into my Firebird?
