Oh white chocolate I showed you how to check this thing out. Add the fluid until it pours out the check plug I told you about. Plug it up and start vehicle and shift through all the gears and let it idle until warm. Pull check plug out again and if not runs out add more fluid through the filler hole until it runs out the check hole area and plug again and shift and check until you get a steady little run when you pull the check plug out. Also you are going to need this vehicle in the air to get to the check plug. Also what city you in? I told you I do it for you if your in Los Angeles area. Also just print my instructionsand take to a quick lube center and have them follow my instructions. And what happend to trans guy? You did not want to wait on him?
It should tell you your vehicle fluid capacities in the owner's manual you got with the car. One question will be whether it includes the fluid in the torque converter or not. Also there's fluid in the radiator cooler for the transmission and the lines running to it.
