how to put a turbo charger in pontiac
  • Thread starter Thread starter google
G
google
grand am!? it is a 1994 pontiac grand am. what will happen if i put one of thoughs thins in that car will it work? will it fit? how much hp will i get out of it? it does not already have a v6 in it i think its just a 4 cylander!
right now it has about 175 hp! but its old so probably not getting all the horses out of it!
Unfortunatly the engine in your Grand Am wil not take to turbo charging well
they simply are not made for it and little is available for any conversion even if you wanted to do it , I would say you would be better off buying a different car mabye one with a better engine with a turbo allready installed ..
you would spend as much trying to put one on your car as getting a different one ...
By experence go buy soemthing already turbo charged... Like a Eclipse GSX/Eagle Talon TSiAWD (awsome cars had 2 of them) but they break alot. Your block wont hold up to the ppower that a turbocharger adds to it unless you really want to do a complete rebuild then at that [point u can prob go find yourself a cheap honda or something already charged....
Find youself a used GTP. You'll still have a Pontiac and it'll already be superch arged. Much more reliable than a DSM. More class than a DSM and you can build more boost with a small pulley and a MAFT. A 94 GM 4 cylinder will most likely become scrap metal with even 3 - 4lbs of boost.
