Witch way do you turn the tire iron?there wil be a cut out in th carpet in the back when you lift up the hatch. you will have to use the tire iron that came with the car in the nut to lower the tire from under the car
Bottom part for sqare broke what to dothere wil be a cut out in th carpet in the back when you lift up the hatch. you will have to use the tire iron that came with the car in the nut to lower the tire from under the car
