how to replace clutch
  • Thread starter Thread starter Dudgy
D
Dudgy
I got a 91 and 94 sunbird and i wanna put the clutch from the 91 into the 94 but don't really know how to do it. can someone help me get started.
thanks:cool:
why would you go through that kind of trouble, pulling the transmission, and not put in a new one?
always replace clutch and pressure plate w/new or reman. any rattle in the bearing and it should be replaced w/new. also a good time to check rear engine oil seal for leaks. fwd and you may have to pull the engine. get a haynes or chilton manual for that model and read up. parts about $100. buying new instead of swapping saves you from doing the job twice.
