what is a gauge delete and what is the purpose of replacing the existing cluster?
1. Disconnect battery and remove lower a/c duct if equipped.
2.Remove lower instrument panel trim and glove box.
3.Lower steering column.
4.Disconnect speedometer cable and heater cable at heater case.
5. Remove 3 instrument panel screws at gages.
6.Remove 3 right instrument panel nuts.
7. Remove lower instrument panel bolts at right and left ends and at steering column.
8.Position crash pad outward on steering column.
9. Disconnect printed circuit.
10. Remove instrument panel harness retaining screws.
11.Remove cluster retaining screws and cluster.
