Are there any special procedures to bleed brakes on a Pontiac grand am (1995) there is no fluid coming out, but there is fluid where it is supposed to be.
Can you be more specific as to what you are doing. Did you remove the cap from the brake master cylinder? Are you gravity bleeding or having a friend pump the peddle? Why are you bleeding the brakes? What does "there is fluid where it is supposed to be" really mean?
