1990 firebird 305 multi port ijectinon. Starts rigt uo in the morning. Drive's no problem. Wen I shut it off it will not start again. if I let it sit all night. it wil start right up an drive. HELP
Sounds like it could have fuel pump issues sometimes when they heat up they will run fine and then when shut off they are too hot to start (the electric motor in the pump) I would get a fuel pump gauge and check fuel pressure when it won't start .. that should give you a good idea whats up ...
