J
jeff
I replaced the thermostat, replaced the water pump, and replaced the intake manifold gaskets. Still over heats. I removed the thermostat and left it out. Replaced the water pump again. still over heats. There is no warm air in the heater vents. There is no water in the oil. The exhaust is clear, no white or smoky exhaust. No signs of leaking. I replaced the upper radiator hose with clear tubing to see the coolant flow. No coolant flow is visible. I do not think water is ciculating thru the engine. It will idle without over heating, but as soon as you put it under load. It over heats.
