i have a 2000 pontiac grand am low collant light went on checked it it was low...
  • Thread starter Thread starter Danielle D
D
Danielle D
...under hood smelled bad? my coolant is low can smell it under the hood and its hot under there but not over heating when driving it
Check all the hoses for leaks or leaking connections. If it is leaking, there should be a wet spot somewhere. Also, the water pump has a hole on the underside. If it is leaking there, replace the water pump.
