i have a 2000 pontiac grand am se1 and the blower isn't working?
whitney dassow
my pontiac grand am se1 has a problem... the heater was working this morning and when i came home yesterday it wouldn't work on any setting, we looked at the fuse for the blower its not blow we replaced the relay and it still doesn't work could the fan be froze? the temp dropped and its been snowing but where do i find the fan. or do you have anyother suggestions please help i can' t go to work with no heat its spose to be below zero tomorrow.
sounds like your blower motor is bad. check for power and ground at the 2 wire connector that plugs into the blower motor. if you're good there the the blower is bad. good luck.
