i have a 2004 pontiac sunfire with no second yellow wire (not the speaker wire)....
Daniel
...what should i do? im installing an after market jvc with one less wire and no switched . dimmer and amp trigger is not a labeled wire on the new radio this is not the first radio Ive install but it is the most problematic . extremely frustrated please help
Did you get the proper $150ish harness to plug it into? If not, then even if you did get this to work, you will lose your door chimes, and your air bag light will come on in your cluster (and MAY or MAY NOT go off in an accident.....leading to no insurance coverage)
But in regular installs, 8 of the wires are for the speakers (green, green-black, gray, gray-black, purple, purple-black, white, white-black), red is power, yellow is ignition, black is ground, blue (or blue-white) is amp turn on.
Hope this helps a little
