I have a 99 pontiac grand am. and the VSS is going bad on it.?
  • Thread starter Thread starter jkirby87
J
jkirby87
I don't have the money to replace it and I have the skill to do it but I don't have the know how. i am trying to bypass the vss on my vehicle because it will only let me go up to 65 miles per hour. please help me
The VSS (vehicle speed sensor) sends the vehicle speed to the speedometer and cruse control circuits and may also correlate the shift points with an electronic controled transmission ...
it is needed to regulate shift points and may be what is causing the speed to be limited to 65 by not properly regulating the shifts ..
there is NO way to bypass the speed sensor when a electronic transmission is there
you need to have it to tell the trans to shift , there is no way around it you will have to have it fixed properly or risk burning up the trans ..
