I've no idea what the ETS OFF is indicating.
The ABS is your Brakes and you still have Brakes, just not Anti-Lock.
The ABS Light may simply be a Wheel Sensor which sometimes a wee bit of dirt can have the ECM send a Fault Code or it could be the ABS Relay.
Supposedly Auto Zone can check the Codes for FREE, or you can purchase a OBDII Code Scanner/Reader that is accompanied by a book of Codes at Auto Zone, Advance Auto, O'Reillys, etc.
The Port for hooking up a Code Scanner/Reader is usually located on the Steering Column near a Fuse Panel.
